Seat bases that I've started
Old Aug 27, 2014 | 07:51 PM
56panelford's Avatar
56panelford
Not quite finished but thought I'd share the base I made for my seats
1956 Ford F100 4x2 - Bucket Seats
Old Aug 27, 2014 | 07:55 PM
avf100's Avatar
avf100
Is that a slide out BEER storage compartment ??
Old Aug 27, 2014 | 08:08 PM
56panelford
should hold ice
Old Aug 27, 2014 | 08:14 PM
clintonvillian's Avatar
clintonvillian
Didnt know you had another build besides the panel!
Old Aug 27, 2014 | 08:20 PM
56panelford
Just working on the cab right now, another 56 but a pickup this time.
Old Aug 27, 2014 | 10:17 PM
yamagrant's Avatar
yamagrant
Lookin Good John!
Old Aug 28, 2014 | 05:39 AM
Drewski 2's Avatar
Drewski 2
John, looks like you've got the seat mount under control. I don't think my mounting system would have helped you much since my seats are mounted directly to the floor. If I hadn't chopped the top I would have been doing something similar to what you've done.
Have you got that maze of wires figured out under the drivers seat yet? I'm really hoping that I can eliminate some of the wiring since the seat memory also controlled outside mirror settings which I won't need. I'm not really sure I understand how the seat memory is still working. I assume the brain to the memory is mounted somewhere in all that wiring.
Old Aug 28, 2014 | 07:24 AM
56panelford
I had one of the motors that were broken on the drivers seat, I couldn't find another with the memory motors to replace it and the parts are now obsolete. I picked up another power seat from a 2001 Intrepid and switched motors but wouldn't work with the memory unit so just switched out the complete base so I iliminated the memory completely, still going to try and make the heat pads to work. I have a wiring diagram and know you match the 7 wires from the passanger seat to the same coloured wires on the 22 wire plug of the drivers seat, that will help iliminate some of the wires. There is a memory module on the drivers seat that ties into another one in the dash of the doner car that is needed to make everything work. The plug with the 2 wires control all the functions of the seat which is what I was really after.
Old Aug 28, 2014 | 07:54 AM
Drewski 2's Avatar
Drewski 2
Wish I had known that you needed one of the memory motors. I had one that had stripped one of the plastic gears and I went and picked up another motor at my local pull-a-part. On that particular trip I noted 3 different Chrysler products that had the memory seats. Motors $12 each, I would have been glad to pick one up for you and shipped it.
Old Aug 28, 2014 | 09:52 PM
ZFLASH's Avatar
ZFLASH
That looks sweet,just drill a drain hole and attach a hose leading out of the bottom floor board and you'll have that nice beer holder. L8R ZFLASH
52 USCG Panel
38
Mar 6, 2023 09:00 PM
AntiHero55
Jun 19, 2010 11:06 PM
mudmaker
18
Jun 5, 2010 01:01 PM
dylan1952
Jan 12, 2007 12:52 PM
