Surface Rust on Shotgun???
Old Jul 13, 2003 | 09:16 AM
AlabamaBronco's Avatar
AlabamaBronco
Question Surface Rust on Shotgun???
What is the best way to get surface rust off of a shotgun? I recently acquired this gun from a relative who didnt take the preventative measures normally used. The gun fires fine and the wood parts are in good shape, there is just a lot of surface rust on the barrel and receiver. Any help would be great......
Thanks....
West
Old Jul 13, 2003 | 09:48 AM
jim henderson's Avatar
jim henderson
A lot of rust may be a problem. Usually for light surface rust some very fine steel wool and maybe some WD40 applied gently will usually do the trick. Unless this is a collector's piece, you could use some blue touch up and then grease the gun as required.
Good Luck,
Jim Henderson
Old Jul 13, 2003 | 09:54 AM
theologian's Avatar
theologian
I prefer not to use WD40 on a firearm, using instead the solution known as Break Free CLP.
Theo
Old Jul 13, 2003 | 10:05 AM
wabiker's Avatar
wabiker
...It really depends on what you mean by LIGHT surface rust.
If it is just slightly more than discolored, used a bronze brush and lightly scrub it off...WD-40 works fine on this sort of thing...You'll be surprized at how well this will work on even heavier rust deposits...
...I stay away from steel wool on my guns...steel wool rusts too...
use bronze wool instead.
...Once cleaned up wipe down with a Butchers grade silicon lubricant...the stuff they use for their meat slicers etc etc...the stuff is AWESOME for firearms.
DO NOT reblue any collectors grade gun...It WILL reduce the value
Old Jul 13, 2003 | 10:53 AM
AlabamaBronco
Thanks yall, this is not a collector gun. It is a remington 870. The rust hasnt pitted yet or anything so I am hoping that I will be able to get it off. I will try your suggestions.
West
Old Jul 13, 2003 | 09:15 PM
fordtruck87's Avatar
fordtruck87
buddy of mine had a 870 sounds just like urs i took rubbing alcohol on a rag and cleaned it right up
Old Jul 13, 2003 | 09:16 PM
TheWiz427's Avatar
TheWiz427
Like Theo said use Break Free CLP it's great stuff.
Old Jul 14, 2003 | 01:11 AM
SemperFiMac's Avatar
SemperFiMac
I agree, CLP! Put a liberal(I hate that word) coat on and let it sit for an hour or so. I would use a soft bristled brush and while watching tv scrub away. It will take a while, but you run less of a risk taking off any of the finish that's still good. Once done keep a little CLP coated on it to prevent further rusting.
Old Jul 14, 2003 | 05:14 AM
treb's Avatar
treb
CLP for sure is great use on all my firearms does your 870 have smooth finish on barrel or rough peak&valley finish which is more prone to lite surface rust like said by others lot CLP soak at times a nylon brush will do it go from there been there done that
Old Jul 14, 2003 | 10:53 AM
E4corporal's Avatar
E4corporal
i think either CLP would be the best or 3in1 Oil. Both do the trick rather well
Old Jul 14, 2003 | 12:06 PM
Jmatteau's Avatar
Jmatteau
I had good luck just wiping mine down with rem-oil....Good Luck.
iggybob44
62
Sep 24, 2009 03:11 PM
mark a.
Jan 26, 2008 07:05 PM
mikemc
Sep 25, 2004 08:56 PM
superrangerman2002
28
Feb 8, 2003 02:35 AM
