429 bent pushrod
Old Jul 13, 2003 | 07:35 AM
ranger429's Avatar
ranger429
429 bent pushrod
i just got done with my 70 429, #3 cylinder bent the intake pushrod and 10 of the other pushrods are showing significant wear around the guide plates while the other 5 show little to no wear at all. i am running roller rockers. could it be they were not adjusted correctly or non hardened push rods?thanks
Old Jul 13, 2003 | 08:10 AM
georgedavila's Avatar
georgedavila
429 bent pushrod
Sounds like a combination of both.
Old Jul 17, 2003 | 04:24 PM
ranger429's Avatar
ranger429
429 bent pushrod
well after getting some comp cams hardened pushrods from summitt, i found that the number 3 intake lifter got pushed out of the hole. after messing around with a magnet for 6 hours yesterday this morning i decided it would be faster to just pull the intake. 4 hours later i got it all back together and now it is running excellent.
WORD OF ADVICE: always use hardened pushrods with roller rockers and if you are not sure buy a new set. it would have been worth the 120 bucks from the get go
Old Jul 18, 2003 | 06:43 AM
georgedavila
429 bent pushrod
You must run hardened pushrods with guideplates, regardless of your rocker arm type. The guideplate is what galls the pushrods.
65'f1004x4conver
57
Dec 7, 2006 03:05 PM
videomkr
Apr 21, 2006 06:47 AM
alwig
1978 - 1996 Big Bronco
Mar 12, 2006 08:13 PM
Shelby Sam
Apr 10, 2004 01:10 PM
original67
Feb 28, 2004 06:56 PM
