6.9l - Bent Pushrods
Old Apr 20, 2006 | 09:57 PM
videomkr's Avatar
videomkr
Unhappy 6.9l - Bent Pushrods
I have a 1985 F250 with an ATS Turbo Package. I've benn running this setup for 7 years with no problems. Lately, I took my truck into the shop for some mimor repairs. When they had finished, they noticed that the engine was missing. After chacking all the injectors, they found that the rear cylinder, drivers side, had bent both pushrods. The pushrods were replaced and the motor promptly started missing again, after another inspection the pushrods on the same cyclinder and the number 2 cylinder on the drivers side both bent pushrods. The head was removed, no problems found. The valves were leak tested and the head re-installed. And again, the pushrods on the drivers side rear cylinder only this time were bent. A compression test of all cylinders showed that the compression was good. The rear cylinder had bent the exhaust valve and could not be tested. Please, Some one, Anyone, who's been trough this - Why is the engine bending pushrods??????
Old Apr 20, 2006 | 10:24 PM
PLC7.3's Avatar
PLC7.3
First what were the minor repairs.
Pushrods usually only bend if the valve hits the piston top, usually caused by the lifter rocker assy being torqued down when the engine is not at TDC. The other reason is the lifter not being bled off correctly before starting by rotating the engine by hand several rotations to ensure the lifters/valves/pushrods/cylinders do not conflict with each other. This usually only happens if the rockers and or heads are removed which allows the lifter to expand. When the lifter expands it makes the stroke of the pushrod longer on the first strokes and holds the valve open which contacts the piston and bends the push rod. There is only 35 thou between piston top and head, with about 50 thou plus 35 thou = 85 thou from the valve seated to the piston face at TDC.
Old Apr 21, 2006 | 04:54 AM
bilder12's Avatar
bilder12
high engine rpm will also cause the pistons to hit the valves -- bending the push rods. Usually downshifting at the wrong speeds. You got a new driver on the truck ??
Old Apr 21, 2006 | 05:53 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome videomkr to Ford Truck Enthusiasts!
…..See you on the boards.
Old Apr 21, 2006 | 06:47 AM
PLC7.3's Avatar
PLC7.3
Do you have a Exhaust brake installed, that will float valves and bend pushrods too,
TheBlueMule
May 18, 2015 06:59 AM
BADASS 65 RANCHERO
Mar 27, 2014 12:33 PM
Jayman1976
Jul 26, 2013 06:41 PM
dyoungen
20
Oct 9, 2012 11:18 AM
fordman428
Aug 30, 2004 09:02 AM
