HELP?!?!
Old Aug 26, 2014 | 06:23 PM
Little_ranger86's Avatar
Little_ranger86
HELP?!?!
I have a 1986 ford ranger with the 2.9 v6 5 speed, i have a problem when applying steady gas it revs up and down up and down but only at a certain amount of pressure on the pedal. Any help will be appreciated
Old Aug 26, 2014 | 11:28 PM
Mikeman's Avatar
Mikeman
A little more detail would help. Is it revving up and down when you're driving? How much throttle are you giving it when it does this? What engine speed? Does it happen when hot or cold? Fuel injection or carb?
Old Aug 29, 2014 | 09:49 PM
Little_ranger86
Its fuel injection about just a 1/8 or so fuel and yes when driving and sitting still. And it does it hot or cold
Old Aug 30, 2014 | 12:22 PM
87 XLT's Avatar
87 XLT
You need to do 3 quick and very simple tests.
1. Check for any trouble codes. An innova 3145 makes pulling codes VERY simple. Check out the reviews at amazon.com
2. If pulling the codes doesn't tell you what the problem is you need to VERY SIMPLY check the fuel pressure. Harbor Freight has the pressure gauge for about 20 bucks.
You want the one for fuel injection.
Still no joy? You need to test with a vacuum gauge. Harbor Freight might have those also.
On 1988 and newer Rangers you can use the CEL/check engine light to pull the codes, but the 1st Ranger that was equipped with a CEL was 1988.
What makes the innova 3145 so simple to use is that it pulls stores and displays the codes. No need to count flashes like on my actron scanner. Or you can pull the codes with an analog volt meter.
On my 87 the test connector hangs at the end of it's wires under the hood near the heater blower motor. Should be the same on your 86
Old Aug 30, 2014 | 01:22 PM
87 XLT's Avatar
87 XLT
Your post made me wonder how my 87 2.9 is doing vacuum wise. Took a drive to warm it up & put the gauge on it. Still pulling a nice steady 20 inches. Not to shabby for 240,000 miles. It's not easy to kill these old Rangers.
BTW. have you checked for vacuum leaks??
Old Sep 4, 2014 | 08:52 PM
Little_ranger86
No but thanks for the responses I'll give it a try.
jimbojbcj
Apr 22, 2013 10:03 AM
KaoticCreations
41
Sep 24, 2009 11:01 PM
seekfuntime
Nov 5, 2007 12:25 PM
jeff8abug
17
Dec 13, 2004 02:14 PM
ryantremblay
Dec 1, 2004 07:58 PM
