motor idles up
Old Aug 26, 2014 | 01:21 PM
SScars's Avatar
SScars
motor idles up
i just put a fresh C6 behind a 351M and when I put it in drive she idles high, and tries to take off. it does not do it in reverse. I tried different combinations with the vacuum lines. I even tried to plug all vacuum line outlets. Any Ideas?
Old Aug 26, 2014 | 03:03 PM
fmc400's Avatar
fmc400
MSEE
Well, have you adjusted the idle speed and idle mixture? What specific troubleshooting have you done?
Old Aug 26, 2014 | 03:38 PM
SScars's Avatar
SScars
Just about everything. Two and a half turns on mix. Plugged and unplugged vacuum. I'm starting to think Mabe a locked up torque converter. She idles fine in park. Handles we'll in reverse. But in drive, she takes off like a raped ape.
Old Aug 26, 2014 | 03:44 PM
SScars's Avatar
SScars
I put an egr delete/ spacer plate off of a 74. Mabe it's leaking air
Old Aug 26, 2014 | 04:49 PM
fmc400's Avatar
fmc400
MSEE
What about idle speed?
Okay, so there has been other work done beyond what you originally stated in the first post. What is the full story? You can't explain only what you think is important.
Never mind all the various ways you've tried to connect vacuum lines. Hook it up the right way. There is only one vacuum source to the transmission; that is the vacuum modulator and it connects directly to manifold vacuum.
Old Aug 26, 2014 | 06:06 PM
JWC 3's Avatar
JWC 3
Maybe a stupid idea.... how are your motor mounts?
chessman21
Feb 12, 2011 08:32 AM
IreallyLikeFords
34
Apr 27, 2009 09:59 PM
muckypaws
1978 - 1996 Big Bronco
Dec 28, 2005 06:02 AM
downdeephuskyjerk
Oct 25, 2003 11:35 PM
72_ford
Feb 14, 2002 09:07 AM
