2000 f350 electrical problems
Old Aug 26, 2014 | 09:03 PM
DieselDenny's Avatar
DieselDenny
Just as an afterthought to you finding your problem. (Super glad you found it!)
Lets just say in the future you have a few gremlins appear in your electrical status..........
Such a loss to lose the initial problem why you just were here!
Never forget (or write it down where your wife can find it)
Denny
Old Aug 28, 2014 | 11:09 PM
retiredsparky's Avatar
retiredsparky
There is a common way to locate windshield leaks:
Lower one window enough to install shop vac hose into truck.
Duct tape the opening around the hose.
Connect the hose to the outlet side of the vacuum ( after emptying the dust out).
Turn on vacuum (you are now blowing air into the vehicle).
Pour weak solution of car washing soap around edge of windshield.
If there is a water leak, the air will also leak out in the same area, blowing bubbles.
Larry
jagottuso1
Mar 31, 2019 12:17 PM
jose0504
Feb 14, 2018 08:43 PM
ccattie
Aug 8, 2012 07:09 AM
blitz10
Feb 21, 2003 08:30 PM
