rust repair patch panel recommendations
Old Aug 25, 2014 | 11:23 AM
turnkyle's Avatar
turnkyle
I am looking to patch in some rust repair panels in extended cab portion of the rocker panels of my truck and was wondering what brand most people get. It seems the main suppliers that I have found are LMC truck and Jeffs Bronco Graveyard. Has anyone bought panels from these guys? How was the quality, fit and finish? Any other suppliers out there that have a better or same quality product?
Thanks.
Old Aug 25, 2014 | 02:35 PM
krooser's Avatar
krooser
Google 'ford patch panels and take your pick'...
Old Aug 25, 2014 | 02:37 PM
turnkyle's Avatar
turnkyle
Are they all basically the same or are there some that are better/thicker metal?
Old Aug 25, 2014 | 02:41 PM
krooser's Avatar
krooser
I've always bought mine from a local outfit here in Wisconsin or at auto swap meets. I can't speak to the quality of others but, like anything else, I'm sure there are differences.
Old Aug 25, 2014 | 03:21 PM
irishbum351's Avatar
irishbum351
A guy at my work uses LMC for his GM trucks, he seems to like them. Might also be because its local and he can run out there and pick them up from their showroom. Worth a look at least
SteelHorse4x4's Avatar
SteelHorse4x4
I bought a set off ebay for 89 last spring
Thickness was good, fit on front required some tweeking. If you have any metal work experience its not bad. Just be prepared for some metal replacement inside of the outer skin. Also, get as much foam out as possible, don't want a fire. Get some weld through primer too.
Old Aug 25, 2014 | 04:08 PM
turnkyle's Avatar
turnkyle
I am hoping to catch it early enough that I won't have to replace much inner material. Didn't think about weld through primer though, good advice. I don't have much metal working experience so hopefully they will line up pretty good.
Old Aug 25, 2014 | 04:33 PM
turnkyle's Avatar
turnkyle
Anyone order panels off of fixmyrust.com?
Old Aug 25, 2014 | 08:12 PM
Diesel_Brad's Avatar
Diesel_Brad
I like NPD or Bronco Graveyard. LMC is pretty much junk
Old Aug 26, 2014 | 03:55 PM
turnkyle's Avatar
turnkyle
Brad, how dos the quality compare between the two suppliers, fit and finish? Seems like NPD has slightly better prices than Bronco Graveyard, unless Bronco Graveyard gives a discount to FTE member....
Old Aug 26, 2014 | 06:34 PM
Diesel_Brad
After the handful of things I bought from LMC were wrong or JUNK I stopped buying from them.
Prime example:
79 F150 wheel well trim. it took an HOUR per wheel well to bend and mold the trim to fit. You would of thought they sent me ones for a dodge(I called and the part # was right)
DavenTn
Oct 12, 2015 06:09 PM
tjbradney
Paint & Bodywork
Mar 29, 2015 03:25 PM
turnkyle
41
Oct 5, 2014 02:02 PM
CdnSoldier
Paint & Bodywork
Jun 12, 2005 07:14 AM
sampsin
Paint & Bodywork
Dec 28, 2002 10:52 PM
