Need some help diagnosing
Old Aug 24, 2014 | 07:44 PM
forresty17's Avatar
forresty17
Hey guys, I have a 93 351 Windsor in an f-250. While driving at random times the gas likes to stop working and it will just bog the truck down. When i down shift and shift back up it goes back to normal though. I have noticed that it also like to idle high randomly as well. I was assuming that it might be a problem in the throttle control but I am still pretty new to this all. Any help or ideas?
Old Aug 25, 2014 | 02:18 AM
xlt4wd90's Avatar
xlt4wd90
I'm not sure what you mean by "gas likes to stop working" Does the engine just start to bog at some point? I had something similar happen shortly after changing a fuel filter. When I hit a bump, the engine would stumble. Sometimes the stumble would persist until I turned off the engine. Then it would run OK for a while, and repeat after another bump. I suspected the fuel filter, changed it again, and the problem went away. I should have cut it open to see what might be clogging things up inside.
Old Aug 25, 2014 | 08:17 AM
forresty17's Avatar
forresty17
Sorry, should have been clearer on that part. Say you were holding the gas pedal at half throttle or so for a continuous amount of time. Well, at some point the throttle just stops giving the truck no power whether you let off or hammer it. It doesn't even rev up the rpm's it is like the throttle cable was disconnected altogether. When i down shift and shift back to whatever gear (never letting off the clutch) it goes back to normal for a while. I am gonna change the fuel filter and see if that has any affect though.
eatont9999
Jul 6, 2011 11:19 PM
retiredbo
Sep 27, 2008 02:03 AM
FORD MEGA CAB!!!
Aug 20, 2008 10:35 PM
Black89F150
Sep 26, 2004 10:43 PM
paddler
Mar 31, 2003 08:55 PM
