Dip stick plug
Old Aug 24, 2014 | 02:28 PM
bluegoose95401's Avatar
bluegoose95401
Dip stick plug
I have been working on the motor out of my 74 f100 4x4 I know that the motor was replaced by the P/O it's a 390. The issue i have at this point is there is a hole in the block next to the oil filter housing. I believe this is from a car or 2x4 dip stick. The P/O stuck a piece vac hose in there and put a screw In the end of it to tighten it up. I would like to correct this what's the best way to do that
Old Aug 24, 2014 | 04:53 PM
Roger Carter's Avatar
Roger Carter
I have used cup plugs to plug those holes. Most auto parts stores carry an assortment of sizes.
A little Permatex and a couple taps with a hammer is all it takes.
Good luck.
Old Aug 24, 2014 | 05:12 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yeah, the same little plugs they use in the ends of the oil gallies.
thebarnyard13
Jul 29, 2010 03:41 PM
cparks
May 1, 2009 03:44 PM
Shep VA
Modular V8 (4.6L, 5.4L)
Mar 14, 2008 07:03 AM
ltj427
Dec 25, 2005 07:16 PM
mobleyt
Jul 22, 2002 01:33 PM
