Sponsored by: Real Truck
Bulletproof 6.0
Old Aug 24, 2014 | 02:01 PM
Robb Kiker's Avatar
Robb Kiker
Bulletproof 6.0
Hey Fellas:
Have a 2007 F250 6.0 diesel with the standard issues including misfire at highway speed.
Perhaps a stupid question: Assume the bulletproof kit also cures the stiction problem? in reviewing the threads and looking at the vendors, references are made to fixing the oil cooler issue, egr issue, etc., but no one addresses stiction issue directly.
What kits have you installed and recommend?
Thanks so much.
Old Aug 24, 2014 | 04:20 PM
r2millers's Avatar
r2millers
Originally Posted by Robb Kiker
Hey Fellas:
Thanks so much.
Lots of discussion about using Archoil. See link below.
I know I started to get what I thought was stiction but it ended up being a stuck turbo unison ring. Once the turbo was back in order, the stiction symptoms went away.
Archoil - The Most Effective Injector Solution
Old Aug 24, 2014 | 09:11 PM
Robb Kiker's Avatar
Robb Kiker
Thanks for the link and reply.
So the bulletproof kits do not fix the stiction problem?
Still have to deal with that separately?
Old Aug 25, 2014 | 12:14 AM
Trophy_23's Avatar
Trophy_23
What were the symptoms? I am curious because I am bulletproofed but the turbo has never been touched.
Old Aug 25, 2014 | 05:19 AM
T diesel's Avatar
T diesel
You really need to post in the 6.0 section.
Great amount of knowledge there!
Old Aug 25, 2014 | 05:57 AM
Number21's Avatar
Number21
Stiction is caused by injectors. Worst case scenario you will need new ones. They are not part of any bulletproofing.
Old Aug 25, 2014 | 07:53 AM
r2millers's Avatar
r2millers
Here in So Cal, cold is in the 50's. In the morning when "cold," I would get the romps while warming up initially, very similar to those described with stiction. I had to drive it for several miles to eliminate the miss that went along with the romps.
Once warmed up, all symptoms went away.
After the turbo unison ring repair, start up acted perfectly normal again. No romps at all.
Who would have thought?
Old Aug 25, 2014 | 08:30 AM
Robb Kiker's Avatar
Robb Kiker
Did not realize there was a 6.0 section.
Thanks Will do.
Old Aug 25, 2014 | 10:47 AM
T diesel's Avatar
T diesel
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Old Aug 29, 2014 | 09:01 AM
BoKnowsDiesel's Avatar
BoKnowsDiesel
Former Vendor
Our Stiction Eliminator will completely rid an engine of any stiction buildups
Old Aug 31, 2014 | 02:45 PM
rowekmr's Avatar
rowekmr
I thought I had stiction and used the Archoil with minimal improvement. Turns out that 4 injectors were bad so replaced all 8 and had the bulletproofing done (HG/studs) and after K's of $$$ replacing other worn components she drives like new. Are you sure other parts aren't bad that could cause similar issues?
What issues/symptoms do you have?
Jammer754
Jun 9, 2014 04:39 PM
woodythefordboy
Dec 12, 2012 07:55 PM
mt96
May 8, 2009 08:04 PM
dominantdeer
Jul 27, 2006 07:26 AM
