Points keep burning up
Old Aug 24, 2014 | 12:27 PM
Davehart24's Avatar
Davehart24
okay so i have a 1977 f250 with the stock 400. the truck has been switched over to points from the original electronic ignition. so i have put 1500 miles on the truck and burnt through 3 sets of points and condensors already. what might cause this? the coil is getting 12-13 volts all the time but the coil is a "non external resistor required". any ideas? Also, i have been thinking of switching over to an aftermarket electronic ignition. Possible pertronix ignitor 2. Has anybody tried this? thanks, dave!
Old Aug 24, 2014 | 12:30 PM
351Cleveland C4's Avatar
351Cleveland C4
The high voltage going to the coil is what's doing it. 12-13-14 volts is way too much for points.
Put in a resistor or go to a pertronix unit.
Old Aug 24, 2014 | 02:50 PM
EP145's Avatar
EP145
Yes a resistor is need. I put an Accel version of the Pertronix in and love it! My timing was jumping around and now it is stead as can be and it was less than $100 bucks.
Old Aug 25, 2014 | 08:03 PM
fmc400's Avatar
fmc400
MSEE
Agree with the others; despite what your coil may be rated to handle, stock points are not rated for full voltage. Other things that can burn through points are too fine of gap, misalignment, or a bad condenser, but a bad condenser is usually accompanied by strong misfire.
What gap are you running?
Old Aug 25, 2014 | 08:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The truck should already have a resistor, this:
D7AZ-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-213).
49" long / Color coded red / 1.30-1.40 ohms resistance / #16 gauge wire.
1977/89 F100/350, Bronco & Econoline.
Old Aug 25, 2014 | 10:06 PM
EP145's Avatar
EP145
If his truck had electronic ignition on it would it still have resistor wire on it?
Old Aug 26, 2014 | 06:26 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes, there is still a resistor circuit.
Old Aug 26, 2014 | 07:13 AM
NumberDummy
Absolutely!
DuraSpark electronic ignition introduced in 1974, but not all vehicles had it until 1976.
The resistor wire I posted was introduced in 1977.
Old Aug 26, 2014 | 07:29 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's the resistor circuit for the Dura-spark ignition (red outlined box),
Old Aug 26, 2014 | 07:52 AM
David7.3's Avatar
David7.3
Maybe the PO removed it for the new ignition system, He had the opposite problem, not enough voltage to the module or coil and cutout the resistor wire.
Old Aug 26, 2014 | 08:52 AM
EP145's Avatar
EP145
Thanks Mike and Bill.
Old Aug 26, 2014 | 09:04 AM
fmc400's Avatar
fmc400
MSEE
While the part number may have changed to accommodate different wire lengths or terminations, both points and Duraspark use a ballast resistor as Mike points out.
Old Aug 26, 2014 | 10:46 AM
NumberDummy
Exactly!
COLF-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-37).
61.49" long / Color coded pink / 1.30-1.40 ohms resistance / #20 gauge wire / All 1960/70 FoMoCo vehicles, some 1971/76's.
D1AZ-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-84-A).
60" long / Color coded red with green stripes / 1.30-1.40 ohms resistance / #16 gauge wire / Some 1971/76 FoMoCo vehicles.
Old Oct 3, 2014 | 12:39 AM
C-AREVALO's Avatar
C-AREVALO
I got to ask where do this wire go to cus i retrofitted my 79 ford to a points type ignition cus my electronic ignition wires were all hacked. How is it routed. Any help would be appreciated thanks...
Old Oct 3, 2014 | 04:43 AM
jim collins's Avatar
jim collins
You should be able to just add in a resister out next to the coil i would think, the experts here can tell you for sure.
