Points keep burning up
Old Oct 3, 2014 | 11:13 AM
ZarK-eh's Avatar
ZarK-eh
Originally Posted by jim collins
You should be able to just add in a resister out next to the coil i would think, the experts here can tell you for sure.
Like this I presume http://shop.citroenclassics.co.uk/ek...tor.-112-p.jpg
Only problem with this I can see is cold weather starting. Fuel takes a lot more energy to ignite when cold. There should be a wire attached to the I on the starter solenoid which feeds the coil full voltage (bypass the ballast resistor) to give it extra oomph during crank. Also, running full voltage would overheat a stock coil or any coil not designed to handle it.
Think about it, for every engine cycle, this coil is building up a charge 6 or 8 times! there is only so far you can go with performance and why most manufactures went with wasted spark coils or individual coils per spark plug to run fat dwell times.
Look at your under dash harness from about the fuse panel to about centre of dash for any hackery there which is where that resistor wire is located. Repair this for the best fix.
Or swap away from points and use a full voltage coil suggested by 351clevlandC4 and EP145.
Old Oct 4, 2014 | 02:43 PM
C-AREVALO's Avatar
C-AREVALO
Ok thanks guys...
r_reed
Aug 13, 2016 08:15 PM
rustywheel68
Electrical Systems/Wiring
Mar 20, 2013 08:26 AM
roadrash63
Jan 8, 2011 08:32 AM
hayden01
Dec 30, 2008 09:15 AM
woppini
Oct 25, 2003 09:35 PM
