2000 ford van engine swap
Old Aug 23, 2014 | 09:56 PM
nyckidd's Avatar
nyckidd
Have a 2000 ford e350 5.4 v8. Engine is making tapping noise. Wanted to know can a newer year van engine be swapped in? Like 08+ . Have couple 2013s in the junkyards around me
Old Aug 25, 2014 | 07:12 AM
JWA's Avatar
JWA
The long blocks would probably interchange assuming your current heads are of the PI or "performance improved" variety.
Other than that you'll need to retain all wiring harnesses, intake, exhaust, sensors etc from the existing engine--they're all specific to your van year PCM's operation.
If the current heads aren't the PI type I'm not sure what happens then.
Sorry I can't be of more specific help.
Old Aug 28, 2014 | 01:29 PM
nyckidd's Avatar
nyckidd
Thanks JWA. I bought engine and swapped everything that you stated to keep can running proper with no check engine
Old Aug 29, 2014 | 05:15 AM
JWA's Avatar
JWA
That's excellent news NYCKidd---most who swap out salvage engines get a few codes that are quickly discovered and corrected.
TruckinNoob
1997 - 2003 F150
Jan 25, 2008 07:00 PM
oddjob
Mar 14, 2007 04:56 PM
gti
Engine Swaps
Nov 20, 2004 12:50 PM
buyer
Dec 5, 2003 09:00 AM
