Brake booster
Old Nov 10, 2003 | 08:47 AM
66MercMan's Avatar
66MercMan
Brake booster
I want to add a brake booster to my 1980 F-100. I have a slightly newer F-150 parts truck with a booster. I assume this is a fairly easy thing to do. It looks like I can just unbolt booster and attach it to the firewall and master cylinder of the f-100 and hook up vaccum line? Just thought I should check too see if there is anything I should know before doing this. Thnx
Old Nov 10, 2003 | 07:00 PM
Barf_Brooks's Avatar
Barf_Brooks
It's pretty much that simple except you'll need the master cylinder push rod from the power brake truck as well.
Old Nov 12, 2003 | 08:41 AM
66MercMan's Avatar
66MercMan
Great, thanks. This will be a welcome addition to my ride.
Old Nov 12, 2003 | 06:30 PM
bremen242's Avatar
bremen242
You will have to get a different Master cylinder. Power ones are different, at least according to the parts stores..
Old Nov 13, 2003 | 02:40 AM
Torque1st's Avatar
Torque1st
Posting Legend
Just use the booster and MC both from the donor truck.
Old Nov 13, 2003 | 06:58 AM
bremen242's Avatar
bremen242
I was gonna say that, but it slipped my mind!. it'll be easier to bleed if it still has fluid in it..
Old Nov 13, 2003 | 08:31 AM
66MercMan's Avatar
66MercMan
I was just going to use the MC currently on my truck, but if they are different it would make sense, and I will take both off the donor.
Thanks again.
Old Nov 13, 2003 | 05:09 PM
bremen242's Avatar
bremen242
they are, the pushrod from a manual goes directly on the brake pedal I believe.
