Ac problem
Old Aug 21, 2014 | 10:01 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Ac problem
We have a 04 F250 crew cab xlt short bed 4X4 with 6.0 engine. When engine is off for a period of time and the ac switch was left on. The air comes out of defrosters for about a minute then switches to ac ducts. Another problem that happens when we stop for stop sign, the ac starts blowing warm air until we get back up to speed. I suspect a vacuum problem on first item, but where to start? Second item - low freon ?
Old Aug 21, 2014 | 10:11 PM
9228.bobcat's Avatar
9228.bobcat
Pretty normal on these trucks. Might check the pressure. To low could cause it but to high will as well. Orfice might be getting plugged.
Old Aug 22, 2014 | 12:52 PM
69cj's Avatar
69cj
I would have the ac pressures checked first and if good start looking for a minor vacum leak. If it wasn't a minor leak it would default to defrost at all times.
Old Aug 22, 2014 | 01:18 PM
Money-Pit's Avatar
Money-Pit
Ditto...check rubber vacuum connectors for small leak.
If A/C high and low pressures check good...check engine fan speed at idle.
Although not recommended....I have had vehicles with the same "warming" issues at a stop before, and adding a can of refrigerant fixed it.
Old Aug 22, 2014 | 02:34 PM
69cj's Avatar
69cj
Do not just add a can to this system without gauges. It is very finicky.
Old Aug 22, 2014 | 07:08 PM
cheezit's Avatar
cheezit
Look for lines freezing up and developing ice.
Check heater control valve
Old Aug 22, 2014 | 08:34 PM
bigredtruckmi
Veteran: Navy
Thanks will check on Monday. We have a wedding tomorrow to be at by 2 pm
Old Aug 23, 2014 | 06:24 PM
bigredtruckmi
Veteran: Navy
Cheezit, no ice on system, just a lot of condensation on pipes but system did a lot of gurgling when truck shut off for a couple of minutes. Checked this after we got home from wedding
Old Aug 23, 2014 | 06:28 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
If it's taking while to go from the default of defrost to the other vents you either have a small vacuum leak or the vacuum pump is getting weak.
Josh
Old Aug 23, 2014 | 06:40 PM
bigredtruckmi
Veteran: Navy
I'll look into it hopefully next week after I get the tractor repaired and out of the shop.
1999-F150
1997 - 2003 F150
Aug 12, 2017 07:46 AM
85F350IDI
Sep 6, 2015 11:16 PM
john1929
6.4L Power Stroke Diesel
Sep 10, 2011 02:12 PM
jkane121
Aug 10, 2010 02:18 PM
phoneman91
Oct 28, 2006 08:51 AM
