More On 40-47 Outside Door Handle Installation
Like other builders of a 40-47 pickup, I ran into the "outside door installation puzzle" recently when attempting to install a reproduction handle. A quick search of this forum, and especially the discovery of some posts by Elder Rodder, soon had me understanding the issue. Like everything else, they needed some modification. The shaft needed to be shortened and a section of about 3/8" of the shaft need the edges relieved or "notched" to allow the handle to pass through the door latch receivers and be rotated into the correct position on the door (later I found an original handle that fully showed what changes were needed). I can't add anything to that good, previous discussion but as no pictures were available, I thought I'd add a couple here that might help someone that doesn't have an original handle to use as a template. Here they are:
Lumbah
1947 and Older Ford Trucks
16
05-21-2020 02:01 PM
gdub
01-03-2014 09:53 PM
marine1200
04-08-2012 02:46 AM
shooer
04-10-2008 06:17 PM
