6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Firewall insulation sagging
Old Aug 21, 2014 | 07:04 PM
brian1253's Avatar
brian1253
I have read a thread or two about somebody having their truck burn to the ground. My firewall insulation is tore up from working on it and sagging a bit before I even started working on it. I even noticed smoke from under the hood a time or two but only a little but that's enough to scare me. Has this been recalled?
Old Aug 23, 2014 | 08:30 AM
senix's Avatar
senix
no recall. Tie it up or replace it. Make sure it never touches the turbo and pipes is all you can do.
Old Aug 26, 2014 | 09:32 PM
brian1253's Avatar
brian1253
Cool-Tape - Heat Reflective Tape 010408 | Purchase DEI, CryO2, Ny-Trex, Boom Mat & SPA Turbo Products | Design Engineering, Inc. - Thermal Performance Products
I have found this tape didn't order it yet it withstands 400 degrees constant heat and 2000 degrees radiant heat. I plan to use an adhesive on the back side as well. Just didn't want the thread to go to nowhere for future use. You are welcome future guy reading this after searching. Have a nice day
Old Aug 29, 2014 | 02:00 AM
SANDDEMON08's Avatar
SANDDEMON08
I used a 3M product when mine started to fall, worked good hasnet fell in over a year so far.
**3M? Heavy Duty 20 Spray Adhesive
Old Aug 30, 2014 | 09:19 AM
9228.bobcat's Avatar
9228.bobcat
Starts to sag with age.lol
Old Oct 2, 2014 | 09:52 PM
brian1253's Avatar
brian1253
I actually found the cool tape and the company DEI makes a heat resistant adhesive I couldn't find the 3m stuff in a smaller package than a case of 12 for 90 dollars but I'm sure this will work found it all locally at pep boys.
lawdawg79
May 25, 2018 06:27 PM
James Hendrix
Sep 18, 2016 04:50 PM
ROBBINthaHOOD
Dec 22, 2011 08:48 PM
Ricksred08
Oct 29, 2010 07:55 PM
