Motor swap
Old Aug 21, 2014 | 02:20 PM
Alleycat3677's Avatar
Alleycat3677
Motor swap
Thinking of putting a smaller engine in my 71 F100. How hard to swap a 302 and trans in for my 360. Just new mounts and drive shaft or not easy at all. Lots of rotted out trucks with good motors here in NY.
Old Aug 21, 2014 | 04:03 PM
JEFFFAFA's Avatar
JEFFFAFA
Not hard as long as there is a complete donor you can get the engine,trans,and EVERYTHING around it. From motor mount stands to the driveshaft.
Old Aug 22, 2014 | 12:23 AM
351Cleveland C4's Avatar
351Cleveland C4
If your gonna swap, I'd swap to a newer 5.0/AOD combo from late 80s/early 90s.
Old Aug 22, 2014 | 12:56 AM
Alleycat3677
Is that an easy swap? I'm assuming just get a new intake and carb and get rid of all the fancy electric stuff.
Old Aug 22, 2014 | 05:18 AM
jowilker's Avatar
jowilker
A early 90s 302 or 351W AOD would be the simplest economy swap. After saying that I would look at a much newer EFI engine/tranny set if you have the coins.
John
Old Aug 22, 2014 | 05:52 AM
Alleycat3677
Nope. No extra coin. This will be a little by little project as I run my 360 til it won't go anymore. The 302s are a dime a dozen in NY. The carb and intake will probably cost more than a good motor and trans will :/
Old Aug 22, 2014 | 09:09 AM
351Cleveland C4
There isn't much electric on those engines. It's still all mechanical fir the most part. The EFI is the benefit. Swapping to a carb would defeat the purpose IMO
Calebsdad7
Apr 18, 2019 11:20 AM
REBELboy_327
May 24, 2005 08:57 PM
padd54
Oct 4, 2004 03:09 PM
Tompo 17
Engine Swaps
Jul 30, 2004 09:34 AM
