Sponsored by: Kumho
Tire Size?
Old Jul 12, 2003 | 05:52 PM
rio_bravo_fan's Avatar
rio_bravo_fan
Question Tire Size?
Looking for tires for a 1979, F250, 460, automatic, 8 Lug.
The truck currently has 225/75/16, the truck is going to be used for on road driving, for hauling, and putting boats in the water. Looking for an all around AT. Rims are 16x6 (I think)
How wide can I go? 245?
Any recommendations?
Thanks a bunch..
Mark
Old Jul 13, 2003 | 05:27 AM
13hondacr250's Avatar
13hondacr250
Tire Size?
First off 245 isn't the width, its the height. The 2 digit number is the width. 265/75/16's are easy to find in load D ratings. Those 225's are kind of small. I'm not sure what stock was but you could get better milaged with a slightly bigger tire. BFGoodrich AT's are excellent tires. There quiet, wear a long time, drive great, and looks good too.
Tyler
94 F-250 PSD 5 speed
95 F-150 302 5 speed
Old Jul 13, 2003 | 08:14 AM
rio_bravo_fan
Tire Size?
The 225 is the tire width in millimeters, measured from the bottom of the bead to the bottom of the bead, the 75 is the sidewall aspect ratio, the ratio of sidewall height to tire width at the tread (indicating that the sidewall height is 75% of the tread width), and the 16 is the wheel rim diameter in inches.
Thanks..
Old Jul 13, 2003 | 10:59 AM
mrwizard's Avatar
mrwizard
Tire Size?
Correct, the first number is the width, the second number is sidewall aspect ratio, and third is, of course, wheel diameter. If your wheels are only 6" then a 245/75 is even going to be pushing it just a little, but should be OK. A 265/75, while it may actually fit on the rim, is recommended for at minimum a 7" rim.
Go to www.tirerack.com and click on "search your tire size". There were 78 tires that came up in a 245/75/16. Even if you have no intention of buying online, it's a good place to do some research.
SRTHOMA1
May 11, 2012 03:44 PM
PEI
Jul 24, 2010 05:34 AM
Paid to Hunt
33
Mar 1, 2006 03:05 PM
1968 F250camper
May 22, 2004 04:29 PM
Viper1837
Dec 12, 2003 07:10 PM
