Tire sizes for lifted excursion
Old May 11, 2012 | 10:54 AM
SRTHOMA1's Avatar
SRTHOMA1
Ok guys. I have a 2003 excursion 4X4 on factory 16" wheels. I want to keep my same wheels. Want to install 7" lift. How big of tire can I go? I was looking at the 345/75R16 and 365/75R16 BFG Mud Terrains. Not many manufacturers are making big tires for 16s. I want to go as big as I can without cutting or spacers. Will NOT put any type of Super Swamper. This truck will never see mud.
Old May 11, 2012 | 11:13 AM
lovestrucks's Avatar
lovestrucks
Your asking for a lot. A 7" kit will usually fit up to 37's (maybe a little smaller/bigger based on tire/rim width combinations).
Those tires you want, won't fit your stock 16" rims. Plus they are mud tires, you said you didn't want swampers because it won't see mud
Stock 16" rims are 16x7 wide and those tires say they need a minimum of a 9.5" wide rim and will fit all the way to a 12" rim width.
If you're spending the money on a lift, don't cut corners on the actually things that connect you to the ground. You will need to go to a wider rim, not necessarily a larger rims, but definitely wider than those stock ones.
If you want more selections of tires look at 17, 18, 20 rim sizes.
Old May 11, 2012 | 11:18 AM
SRTHOMA1's Avatar
SRTHOMA1
It's hard to find tires that big for any rim that are not mud tires. Had bad luck in the past with swampers. Will never buy them again. I was just trying to keep from buying new wheels. I like the stock ones.
Old May 11, 2012 | 02:37 PM
markland's Avatar
markland
315's are about as big as you can go on stock rims and still look good, but you won't need 7in of lift for that, you can get away with 5-6in for sure.
Old May 11, 2012 | 03:25 PM
Lowboy44's Avatar
Lowboy44
I have 37's on my lift with a 9" wide wheel.
Good luck and post pics when done
Old May 11, 2012 | 03:44 PM
lovestrucks
OPEN COUNTRY A/T | Toyo Tires
biggest they offer on the smallest rim
tire size LT355/70R17 127R D/8 (37X14.0R17)
rim width 9.5-10.5-11.0
product code #301360
although it's D-rated it has a max load of 3,860 lbs at 50psi
I'm going to be getting tires soon, and am pretty sure I'm leaning towards these instead of their M/T, because I do more highway
Jeff Kinzel
Apr 19, 2015 10:30 PM
bad4dr
Dec 21, 2007 11:52 PM
Keymaster
Nov 22, 2004 10:13 PM
couleeman
Apr 25, 2004 10:12 AM
theonlybull
Dec 4, 2002 10:45 AM
