More leaves or longer shackles?
Choices?
That would raise the back too much and I would end with up too big of a rate.
Also - how would longer shackles put more stress on the springs?
I'm thinking that I should just raise the whole bed and maybe the cab too. That way I keep the stance and get more clearance.
One other thought Jonf. I added air shocks to my 48f1. Doesn't raise the rear end up too much but stiffens it up so I don't get so much travel. I have a 9" rear and a new rear leaf suspension kit form TCI. Older Corvette air shocks matched up to the conventional shocks supplied with the kit. Just another alternative to consider.
Think of the shackle as a lever, the spring on one end and the weight of the truck on the other. The longer the lever the more force on the spring end when the truck goes around corners. Straight up and and down there is no difference but side to side the forces are greater.
C notching the frame and raising the bed floor may be needed if you do not have enough suspension travel room.
Raising the bed?
Your thoughts??
What truck are we discussing? How about pictures? I left the axle under the springs on my 53, raised the front hangers to to the top of frame rail, and used two inch lowering shackles on rear. I did use some of the convoluted bump stops in the C notches to absorb any contact. With four leaves it rode and drove nicely. New Tbird IRS is even better.:]
I would think raising the whole bed without lowering the fenders will lose the look you are trying to keep. I would raise the bed floor or just a section over the center of the rear.
93F150&69Stang
11-28-2015 01:31 PM
chiefsk
02-14-2013 07:47 AM
rebocardo
07-08-2004 11:05 PM
