Leaking Pinion Seal
Old Aug 20, 2014 | 06:22 AM
mefast's Avatar
mefast
Leaking Pinion Seal
Hello,
I was looking under the truck yesterday and noticed fluid leaking out from around the pinion seal on my rear differential (my truck is only RWD). Would you recommend replacing all of the seals and bearings while I fix this leak? My truck has the standard 3.08 gear ratio (which I don't mind), but it is an open diff and I would love to put a Torsen unit into it. The truck has about 333,000 km (~207,000 mi) on it. Thanks for your help!
Old Aug 20, 2014 | 09:53 AM
subford's Avatar
subford
If you have no pinion noise when the oil starts leaking from the pinion seal you more than likely have a plugged up vent tube.
Old Aug 22, 2014 | 06:56 AM
mefast's Avatar
mefast
That's great info. I'll be sure to check that. Everyone I've talk to says to just get the seal fixed and drive it. There's something in my OCD that tells me that isn't the right way to do things.
bradphx
Feb 25, 2016 11:00 AM
Powerstoke73
Aug 16, 2014 07:54 AM
deemac
May 12, 2010 08:52 PM
pcman
Feb 4, 2005 11:07 PM
69_bronco
Nov 21, 2003 09:46 PM
