Trans shifting problem
Old Aug 18, 2014 | 09:57 PM
notthemaniusedtobe's Avatar
notthemaniusedtobe
In the last 2 days my 73 F250 Camper Special 390, which has been running mostly well for the last year since I bought it, has developed a shifting problem.
When I shift into D, it takes off fine but won't change up at all. Shifting into 2 gives me 1st & 2nd gear, but shifting back to D drops it down into 1st again... wth? I haven't driven it at speed yet to test if it will eventually shift up.
I checked the trans fluid level (changed about 1000 mi ago) and it looks fine, fluid is in good condition too.
Any ideas?
Old Aug 18, 2014 | 10:01 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Check the vacuum modulator and the line that goes to it.
Sounds like either the modulator is bad or maybe the vacuum line has come off.
Check the line for kinks or other problems, make sure it hasn't come off.
If the line checks out, take the line off where it connects to the modulator. If trans fluid leaks out, its bad. If no fluid, it still could be bad.
Old Aug 18, 2014 | 10:25 PM
notthemaniusedtobe
Thanks Mike, I like that option for a quick simple fix. Fingers crossed for a good result tomorrow...
Old Aug 18, 2014 | 10:37 PM
mikeo0o0o0's Avatar
mikeo0o0o0
They're simple to replace, disconnect the vacuum line, remove one bolt that holds the clamp in place and the modulator comes out. It has an o-ring seal.
Modulators are identified by the color of the stripe. Pretty much the "go to" one is the black stripe. If they don't show that one in the catalog, go with the green stripe. Avoid the pink stripe. That one is a dual diaphragm version that has two vacuum line going to it. If by chance you have one of these, replace it with one of the other two and use the vacuum line that goes to direct manifold vacuum, cap the other line.
When you pull the modulator out, be careful. There is a pin that goes in the modulator. Sometimes it comes out with the modulator, sometimes it stays in the tranny. If it comes out, don't lose it.
Old Aug 18, 2014 | 11:16 PM
OldMetal's Avatar
OldMetal
Mike has you on the right track there, he knows his stuff.
Old Aug 19, 2014 | 07:52 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks OldMetal.
Old Aug 19, 2014 | 08:47 PM
notthemaniusedtobe
Done...
Mike, you nailed it! As if I expected any different having read a great many of your posts and responses....
Vac line to modulator was completely fuqued, hose all melty at the top end at the metal line heads towards the carb. And it was disconnected at the trans end.
I went ahead and replaced the vac unit anyway, since I was already on the ground, and it seems to be shifting very nicely now.
Thank you sir, much respect!
Old Aug 19, 2014 | 09:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks, and thanks for the update. Nice to know I helped out.
Sportsterengr
Sep 4, 2021 09:12 PM
beartracks
Aug 6, 2019 10:01 AM
prelag
25
Nov 22, 2016 05:34 PM
Paddrick Smith
Mar 5, 2016 09:34 PM
plefe
27
Jan 10, 2015 11:40 AM
