vacuum modulator
Old Aug 5, 2019 | 03:08 PM
beartracks's Avatar
beartracks
vacuum modulator
need to change the vacuum modulator on my C6. anyone know how much fluid will run out? Will it stop at some point?
Old Aug 6, 2019 | 05:06 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Not much, if any. The modulator is above the fluid line.
Old Aug 6, 2019 | 07:26 AM
SSStang's Avatar
SSStang
Jack the back of the truck up
Old Aug 6, 2019 | 08:57 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
And here is some more info I believe is from mikeo0o0o0? This is a quote from him anyway from a long time ago, I think. lol
Check the vacuum modulator and the line that goes to it. Check the line for kinks or other problems, make sure it hasn't come off.
If the line checks out, take the line off where it connects to the modulator. If trans fluid leaks out, its bad. If no fluid, it still could be bad. They're simple to replace, disconnect the vacuum line, remove one bolt that holds the clamp in place and the modulator comes out. It has an o-ring seal.
Modulators are identified by the color of the stripe. Pretty much the "go to" one is the black stripe. If they don't show that one in the catalog, go with the green stripe. Avoid the pink stripe. That one is a dual diaphragm version that has two vacuum line going to it. If by chance you have one of these, replace it with one of the other two and use the vacuum line that goes to direct manifold vacuum, cap the other line. When you pull the modulator out, be careful. There is a pin that goes in the modulator. Sometimes it comes out with the modulator, sometimes it stays in the tranny. If it comes out, don't lose it.
Old Aug 6, 2019 | 10:01 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Guilty, that was me .
