IPR replacement
Old Aug 23, 2014 | 10:09 PM
carl2591's Avatar
carl2591
Low oil in HPOP could cause funny idle for a bit till it get pumped in.. I have heard it a good idea to remove all the oil in HPOP and refill.
A guy in atlanta that works on a LOT of Powerstrokes put out that info. Take it how you want.. I did a test and a couple hundred miles after the oil was changed i pulled some from HPOP tank and I can see a difference in color.. crankcase oil nice and honey colored,, oil in HPOP tank quite a bit darker.
Old Aug 23, 2014 | 10:23 PM
Pikachu's Avatar
Pikachu
That guy in Atlanta spreads a lot of nonsense like that.
Old Aug 23, 2014 | 10:53 PM
Firefighter 1406's Avatar
Firefighter 1406
What kind of oil do you use that is honey colored any length of time after the truck has been running? Mine is black as soon as you turn the truck over
Old Aug 24, 2014 | 01:50 AM
Blue7.3's Avatar
Blue7.3
I'm using Castrol RX Super and have done 100m and still clean as honey, i do let the motor drain good before i refill.
Old Aug 24, 2014 | 08:53 AM
lhud's Avatar
lhud
Firefighter,
I normally use the Rotella T6 and it would turn black in a couple of thousand miles. Recently I used the Delo 400LE and it would stay honey colored to my next oil change. However, when I drained the oil the catch pan was quite black.
Oh well,
Old Aug 24, 2014 | 08:38 PM
carl2591's Avatar
carl2591
that might be your opinion and you are welcome to it.. but when someone works on powerstroke diesels especially the 7.3 and 6.0L for a living I tend to put a bit more belief in their words vs someone else.
have a good one.
Diesel 724
16
Jul 8, 2020 01:22 PM
A/Ox4
66
Nov 3, 2013 09:04 PM
desertt5
Jan 19, 2010 09:52 PM
meck1
Aug 11, 2009 09:57 PM
fluidp
Apr 25, 2008 11:02 AM
