Would like some advise from Mark
Old Aug 17, 2014 | 04:29 PM
The2003Excursion's Avatar
The2003Excursion
Is there a junction between this area and the actual transmission case that needs to have a gasket replaced?
Old Aug 17, 2014 | 05:04 PM
EXv10's Avatar
EXv10
http://www.moveras.com/images/transm...sions_left.jpg
There is the gasket in front of the t-case housing and the rear of the bottom pan.
Old Aug 17, 2014 | 05:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The seal in the solenoid body can leak fluid into the connector. It takes a new solenoid body to fix this. Unless a lot of fluid gets in there it doesn't cause a problem.
Old Aug 17, 2014 | 06:35 PM
The2003Excursion
Thanks for the image
So I guess the joint at the yellow is not something that is easily serviced/or does not need to be serviced in this situation.
Old Aug 17, 2014 | 07:28 PM
EXv10's Avatar
EXv10
Not easily fixed there. I think the overflow tube ends right about where that leak is also. I would give it a good cleaning there at a quarter car wash and then keep an eye on it.
Old Aug 17, 2014 | 09:50 PM
hav24wheel's Avatar
hav24wheel
Usually that tail housing just unbolts, and that's it. The other stuff stays inside the trans. Jack it up off the oil pan, take the trans mount loose, unbolt the tailhousing, and replace the gasket. No big deal.
Old Aug 17, 2014 | 10:30 PM
EXv10's Avatar
EXv10
So I guess I am wrong. I shouldn't have assumed anything.
cabloom300
Jan 4, 2018 09:10 PM
Dank Hill
Feb 25, 2016 11:07 AM
JaySVX
Nov 5, 2014 11:19 AM
joegeds
Jun 22, 2013 11:54 AM
Headviking
Aug 13, 2010 05:24 PM
