Found a small puddle of trans fluid under my truck upon inspection it looked as though a small amount was coming from a corner in the gasket tightened the bolt on it.
But it seems as though fluid is leaking from this lever on the transmission. Ideas,thoughts,concerns?
Hard to see but it is coming from that lever is plugged in where my finger is at.
Edit it looks like the puddle came mostly from the gasket. But I'm still concerned about the fluid around that lever it doesn't look like it's going to drop.
