early 04 6.0 250 boost problem
Old Aug 16, 2014 | 06:12 PM
luv2brode's Avatar
luv2brode
been looking and seen some similar but not same.
just test drove my 2004 250 after doing the bpd oil cooler and a few other updates. well on the drive I heard a pop and no real boost after. stopped and checked for leaks and intercooler lines, nothing out of ordinary. got fuel drove home boost never got up to 2.0 and was slow to shift also ac started blowing hot.
any ideas?
thanks
Old Aug 16, 2014 | 06:27 PM
BLADE35's Avatar
BLADE35
You MUST post all you did
even post the problems that you had prior to work if any
likely blew the CAC system out somewhere for the boost issue maybe even the uppipe or connection
check the belt tension and Fuses for a/c also can you hear the compressor kick on when flip switch for A/C??
How was ECT??
Old Aug 16, 2014 | 07:04 PM
luv2brode's Avatar
luv2brode
ok ill try to hit it all
bpd oil cooler- did not want to have to keep changing coolers and was seeing numbers 220 or so
updated turbo supply line
updated turbo drain
updated ipr screen
blue spring on fuel bowl
new exhaust down pipe back 4"
discovered egr was already deleted so ended up not using the one I bought, gotta sell that thing now.
of course new oil
new thermostat
new degas cap
I think that is it......
no issues prior that im aware of had not had it long wanted to get things set before I tried using it much
plus side oil pressure made it to 208 max 100 degrees outside
ect 202 or so before tstat opened
Old Aug 17, 2014 | 10:36 AM
luv2brode's Avatar
luv2brode
lower boot under aircleaner had slide off
took same route and drove normal upto about 28 psi boost.
ac issue I think is a Freon issue, was good and cold until almost home then started warming up thinking maybe a little low. and out side temp was only82 right now.
thank you all and still would like to meet some of the local folks I have other things I would like to do and enjoy talking to like minded people.
Old Aug 17, 2014 | 11:49 AM
Mr.Nobody's Avatar
Mr.Nobody
just test drove..... I heard a pop and no real boost after. stopped and checked for leaks and intercooler lines.......
any ideas?
thanks
That darn cold side CAC tube seems to always be the culprit. Do you have the plastic pipe?
Old Aug 17, 2014 | 02:37 PM
luv2brode's Avatar
luv2brode
no metal pipe and this was the pipe end not the ic side don't remember loosening it but good now
kbf1961
Aug 2, 2021 02:15 AM
fordland15
Jul 17, 2019 09:45 AM
Jonota
Sep 7, 2015 03:21 AM
78fordman
Oct 26, 2013 12:11 AM
superdutymanfx4
May 19, 2013 09:58 PM
