Electronic throttle failure.
Old Aug 16, 2014 | 04:14 PM
Radoak's Avatar
Radoak
I have a 2002 7.3 diesel. Fuse # 42 kept blowing on the throttle control. It also takes out the gauges. Finally, installing a new fuse failed to fix it and I am dead in the water. Truck will just sit there and idle. Fuse doesn' blow any more.
Any ideas out there and has anyone else had this problem. Shorted wire?
Old Aug 16, 2014 | 05:18 PM
bigb56's Avatar
bigb56
hmmmmm, you didn't see the answer to your post from yesterday?
Old Aug 16, 2014 | 05:29 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Steering column wire, very common.
Old Aug 16, 2014 | 11:56 PM
AllaboutMPG's Avatar
AllaboutMPG
He may not have. It got moved here from another forum. I know when I first started using boards I posted something only to come back the next day and find it gone. Figured I had done something wrong and it had been removed. Finally figured it out some time later but that didn't help me that day.
Radoak,
Here's a link to your original post with a great write up on your exact problem and how to fix it.
https://www.ford-trucks.com/forums/1...l#post14586713
cowboylmd
Mar 24, 2017 01:08 PM
czydave
Aug 11, 2012 09:05 PM
stewartjwnls
Jul 7, 2010 09:50 PM
vegas_sd
Mar 23, 2008 07:24 PM
xfordtech
May 25, 2006 01:22 PM
