blowing fuses
Old Mar 23, 2008 | 03:42 PM
vegas_sd's Avatar
vegas_sd
blowing fuses
I have an 02 and in the past two weeks i've been blowing the same fuse over and over and its happening more and more often. in the book it shows it as fuse 45, ignition switch run/start feed. but when it blows I loose the warning lights and I loose the throttle, but it still starts up. has anyone had this problem or know anything that may cause this?
Old Mar 23, 2008 | 03:58 PM
fxstbchopper's Avatar
fxstbchopper
Welcome to the FTE..
It sounds like the steering column there is a wire that gets skinned and shorts out in the column had the same problem in my work truck it is an 02 as well.
Old Mar 23, 2008 | 04:56 PM
rebelchevy02's Avatar
rebelchevy02
Our other 02 had that problem, it started sometimes when you put it in reverse, codes said bad throttle assy, but it actually was the fuse block. Something i guess was loose in it, if i remember right, (not mine). But like said above, usually its a wire on the steering column skinned up.
Old Mar 23, 2008 | 05:35 PM
vegas_sd's Avatar
vegas_sd
i'll have to look at it, thanks for the info.
Old Mar 23, 2008 | 07:24 PM
zx250's Avatar
zx250
Of the next Riffraff East
Welcome to FTE. Sounds like they have you pointed it the correct direction. Good luck and let us know what you find.
