I have a 2000 F-150 5.4 L. I was driving from home and seconds after the engine went into a rough idle that wouldn't let me accelerate. I scanned it and gave me multiple transmission trouble codes, about 15. I checked the wiring, the transmission fluid and it all looked good. So, what could be the problem? Help please.
P1704, P1705, P1710, P1711, P1712, P1713, P1740, P1745, P1746, P1747, P1749, P1751, P1754. From transmission system problems to solenoid problems and circuit malfunction. I've checked the wiring and it has some corrosion like green color.
Check fuse 23.
If blown look for a problem that is causing a short to ground that blows the fuse.
This fuse supplies power to all the code listed applications.
Good luck.
