Sponsored by: Real Truck
Pcm issue! Need help
Old Aug 15, 2014 | 07:13 AM
Codyscee's Avatar
Codyscee
New to forums, just bought a 1999 f250 4x4 lariat with a v-10. Truck kept blowing the pcm relay. Took it to a mechanic who replaced the pcm 3 times, then said he needed to replace the instrument cluster. Truck is still not running, no spark, fuel pump staying on when key is on. Fuel pump relay ok. The theft relay under the dash starts clicking a lot sometimes. I am searching for a new wire harness because I found some rigged up radio and light wires under the dash. Any ideas on what else might be contributing to this? Thank you
thegexbird
Mar 17, 2024 07:53 PM
BackyardBronco94
1978 - 1996 Big Bronco
May 15, 2017 08:25 AM
THop
Jun 26, 2009 06:20 PM
TJ272
1997 - 2003 F150
Dec 19, 2008 03:27 PM
Izzy
1983 - 2012 Ranger & B-Series
Nov 8, 2004 04:37 PM
