Sponsored by: Auxito
Yet another PCM relay question
Old Dec 18, 2008 | 08:00 PM
TJ272's Avatar
TJ272
I have a 2002 F-150 SuperCrew. Having same problems as I found in searches related to dashes coming up on the odometer. I want to change the PCM relay, but I'm not sure which one it is.
Can someone help?
One post said it's in the under-hood fuse panel. That's the one on the driver's side, correct? If so, then which one or ones need replacing?
Can anyone supply a picture for a big dummy?
Thanks
TJ
Old Dec 18, 2008 | 09:42 PM
TJ272's Avatar
TJ272
I may have actually figured out on my own ... but questions remain - looking at the diagram in the owners manual, relay in position 304 is the Powertrain Control Module relay, and position 501 is Powertrain Control Module diode. Should both of these be changed or just one, and which one???
Old Dec 19, 2008 | 02:01 AM
eallanboggs's Avatar
eallanboggs
What makes you think a relay will solve this problem? Is this a 7 segment display? If so there may be a way to test all 7 segments of each digits like say on power up. If all 7 segments come on momentarily on power up you know the segments are good. Then the PCM and decoder for the display are the next suspects not the relay. Maybe the PCM is commanding those segment "ON".
Old Dec 19, 2008 | 07:44 AM
projectSHO89's Avatar
projectSHO89
Just replace the relay. The diodes seldom fail.
You should be able to swap the PCM relay with the fuel pump relay. If the original PCM relay was bad, your cluster will now power up correctly although your fuel pump won't run.
It pains me to say this, but you should ignore this as the poster does not seem to have an understanding of what is going on....
Steve
Old Dec 19, 2008 | 01:25 PM
mrluke's Avatar
mrluke
I have this same reading on my 2000, straight horizontal lines on my odometer. My truck cranks but wont start. does your truck start and run? Ford says I need a new ecu
Old Dec 19, 2008 | 03:27 PM
TJ272's Avatar
TJ272
Same symptom, but mine has eventually started each time, so far. Just got off the phone with Ford, relay is $13. Going to try that before spending big $$ on pcm or ecu.
Look back at an old post from Ranger354 (I think). He had suggested tapping on the relay to see if it will energize. As suggested elsewhere, you can also try to change the fuel pump relay for the PCM relay to see if the odometer reading returns. Of corse, the truck still won't start since you are taking the fuel pump out, but it will let you know if the relay is what you need.
Pastor Scott
Nov 11, 2016 09:28 AM
dcgayhart
May 8, 2016 10:11 PM
tmccarthy
Feb 14, 2016 10:46 PM
Tj4861
Jan 19, 2016 12:05 PM
bouncdchk
Jan 14, 2016 05:09 PM
