It's driveable, but I am having the same symptoms as this described in this thread https://www.ford-trucks.com/forums/1...l-to-call.html. The transmission is quick to shift up, but downshifts require a lot of throttle. It seems to shift back down through the gears as I am slowing to a stop just fine. I use "D" around town, and "OD" on the highway. The downshift out of 4th is pretty harsh when I am going up a hill on the highway. The TV cable adjustment looks pretty simple, I found a good video tutorial here
