walbro??should i??
Old Aug 13, 2014 | 07:55 AM
jr2000sd's Avatar
jr2000sd
walbro??should i??
Just had new stage 2 injectors put in and have a fairly new auto-zone fuel pump but was thinking of getting the walbro gl392. Has anyone had any luck with it?
Old Aug 13, 2014 | 07:58 AM
mueckster's Avatar
mueckster
I've had one for ~3 yrs. No problems. Works great.
Old Aug 13, 2014 | 08:06 AM
Tugly's Avatar
Tugly
The OEM will feed the Stage IIs (assuming AC160/100). Are you having fuel pressure issues?
Old Aug 13, 2014 | 08:16 AM
mueckster's Avatar
mueckster
Have you checked the fuel pressure? If you are have a fuel pressure drop, try going to a larger supply line from the tank before swapping fuel pumps.
Old Aug 13, 2014 | 07:12 PM
jr2000sd's Avatar
jr2000sd
Fp should be good i have a frx hutch mod. Pre pump filter with bigger line from the tank and from filter to pump, high flow check valve replacements and drilled out banjo bolts, and new injectors
Old Aug 14, 2014 | 06:16 PM
Gaugepro's Avatar
Gaugepro
Avoid the Walbro. Its not rated for diesel and it will fail. Just a matter of time.
Clay at RiffRaff sells the OEM Bosch, they provide all the fuel you need for 160's to 180's. More then that, simply run two of them.
burns5150
Jul 1, 2012 10:19 PM
biodieselscout
Oct 24, 2010 05:11 PM
WABIT
1983 - 2012 Ranger & B-Series
Sep 13, 2008 09:49 PM
DJdemon6696
27
Dec 2, 2007 04:43 PM
