Anti seize wil not loosen anything. How would spark plugs stay if true? I realize a torque value will change, but who is seriously using a torque wrench on wheels in any garage? They air gun them past the point a 4 way can break them loose half the time.
Both sides make sense here, is it needed, no. Will it hurt, no.
I think as long as you put the anti seize only on the studs you'll be fine, just don't get them on the lug nut where it mates to the rim. This could cause the nuts to not stay tight. Putting anti seize on the hub is all you probably would need to do since it's the corrosion caused by the aluminum wheel/steel hub that's causing the issues.I never use anti seize and haven't had any wheels that wouldn't come off, but I've seen it happen to other people.
Had the truck scheduled in for a trailer brake install (and the tire rotation that they didn't do) and a new key fob (truck only came with one, wife needs one? ). Picked it up, asked how much and they replied 'nothing'. Guess that shows that the dealership is willing to look after their customers.
