I have a very small coolant drip after a yr from waterpump replacement. I drained radiator and put worm clamp on lower hose at the elbow.
Pulled my temp sensor out and threads looked stripped. Put Teflon tape and put back in. Thermostat housing looked dry.
Refilled radiator, that took forever, and truck sat for 7 days and my drip is still there. It's coming from up top down outlet tube, down hose to ground.
Sensor area is wet after wiping everything down.
So do I have to drain rad again to replace my sensor?
Wanna try that before I do thermostat and waterpump gasket.
ya...the pressure from the coolant itself, will follow the path of least resistance, out the sensor hole, once removed. Remove bottom hose and catch the fluid.
If your t-stat hasn't been done in a while I would replace it, or upgrade it with a 203 from fiff-raff, the rubber gasket gets dry rotted and has a tendency to leak when cold, when she warms up it stops, I played around with a coolant leak in that are for awhile and that what it turned out being, I also installed the coolant filter system, since everything was already out, and refilled with ELC, it just may be me but the truck seems to run alittle better, idles smoother!
I just replaced mine here as well. I don't know the difference but NAPA had one for $20+ and the one I got for $10, which seems to be working fine. I put electrical tape over the top of the new sensor and held it in one hand, pulled the old sensor out, using fingers to get the last few threads and held a finger over the hole 'til I got the new sensor in place. Worked good for me. Oh yea, put pan under area to catch what anti-freeze did get away, which wasn't much. Much easier than draining it down.
I do not believe that there is a PCM sensor for our 7.3 diesels. I believe the PCM sensor begins with the 6.0. The sensor in our device has three conditions- cold, normal, hot. The 7.3 does not actually care enough about coolant temp to measure it or send the information to the PCM. The info is inferred from the engine lube oil temp. Without the coolant temp, we can not know how well the engine oil cooler is working. Not very accurate, is it?
A PCM type sensor has what could be called a variable resistance to electrical current which changes as the temp changes. Many automotive sensors have this variable output in either two wire or three wire configuration. This is a much better monitoring system. For this reason with certain scanning programs, the 6.0 can tell you if the oil cooler has a problem. This can be very important information, since oil coolers which are heat exchangers just like a radiator need adequate coolant flow and oil flow to work properly and save the engine from breaking rings, pistons etc. Larry
Alan, thanks for clearing that up about the manual trucks. Too bad those of us with auto trucks can't easily hack into the PCM to add the coolant sensor.
