wheel locking up
Old Aug 12, 2014 | 09:34 AM
gogreenwave's Avatar
gogreenwave
wheel locking up
Hello,
I have been having a problem with my 76 F100 FWD. When I make a very sharp right turn, the right front wheel starts to lock up. It doesn’t completely lockup or skid, but it makes a noise like the tire is rubbing. It does thiswhen I am turning really sharply to the right (only to the right) like when I am pulling into a parking space. I jacked up the front end and turned the wheels to each side and turned them by hand, and they turned freely, even when the steering was turned to the right all the way. I also could not see anywherewhere the tire was rubbing on anything. Could this be an alignment problem? Iam not sure what else to check.
Does anyone have any ideas?
Any help is greatly appreciated
Matt
Old Aug 12, 2014 | 10:01 AM
HIO Silver's Avatar
HIO Silver
FWD? .. Do you mean 4WD?
Sometimes noises don't make themselves evident unless the suspension is loaded.
Have you tried greasing the front end? What condition are the tie rods, drag link, and such?
Old Aug 12, 2014 | 05:44 PM
gogreenwave
Yes, 4 wheel drive. I greased all the steering components, didn't make any difference. I even looked under when it was back on the ground with the wheel turned all the way to the right but couldnt see anything rubbing or that looked wierd.
Old Aug 12, 2014 | 05:55 PM
460 FORD MAN's Avatar
460 FORD MAN
What size tires are you running?
Old Aug 12, 2014 | 06:26 PM
hickory1991's Avatar
hickory1991
Make sure your hubs are unlocked and or check the axle u-joint for wear.
Old Aug 12, 2014 | 10:21 PM
OldMetal's Avatar
OldMetal
Your tire could very well be rubbing on something and your just not seeing it, make some chalk marks on the inside and see if they get rubbed off, also check your ball joints and make sure there is no free play in the wheel bearings. The answer to your problem will be visual somehow.
Old Aug 13, 2014 | 09:14 AM
gogreenwave
ah ha- I feel dumb now- it turns out the tire is rubbing- it is barely hitting the radius arm with the edge of the tire- only on the right side. I got new wheels, same tires put on them, a while back and it must have moved the tire in just enough so it hits on a sharp turn.
I there any way to adjust the steering so it stops before it hits? or a way to shim the wheel out just a tad on the lugs to keep it from hitting? It just barely rubs, but I dont want to damage my tire.
Thanks for the help,
Matt
Old Aug 13, 2014 | 10:57 AM
skidoodave's Avatar
skidoodave
There should be a bolt on the inside of the knuckle that is the steering stop. You can try and adjust it out a bit so the knuckle can only turn so far. If you can't get it to move then you can have someone build up a bit of weld on the top of it to make it hit sooner.
Old Aug 14, 2014 | 09:10 AM
gogreenwave
Thank you!
I will give that a shot.
ohexpy
Jul 13, 2007 10:02 AM
efiguero
2004 - 2008 F150
17
Feb 13, 2006 08:31 PM
F350 Dually
Feb 12, 2005 08:20 AM
kbelanger
Aug 8, 2004 07:46 PM
