My 2007 Super duty 6.0L threw a code with said that #8 glow plug is faulty. So I did a search on forum and read up on how to replace it.
I managed to replace the glow plug by removing the fender inner wall to gain access and cleared the code but the same code came back again right away.
The wiring harness doesn't seem to be broken or damage at all but is there a way to test the wiring harness? Would pulling harness off #8 then using voltage meter and turn ign key will work? Should it give me 12 volt?
I am not loaded and always turn to find way to save money on repairs whenever possible
Could it be any other reason it would throw that code?
I don't think it the glow module because truck still starts fine with the error code.
and also
This is my first Diesel truck owned ( yes I am aware about the 6.0L and wish I did research before buying a diesel truck but it went for cheap)
Am I doing any serious damage to it running on only 7 glow plugs? I am not out driving all over with it just like moving it around on my driveway to work on it?
I read on forums that folks are running their truck on only 7 or even 6 working glow plugs because they didn't want work on it during winter season and want to wait until Spring time to fix it .
You will just have a rough start. Best way is to ohm it out from the gpc plug. But you can also check for voltage at the plug right after you turn the key on with a cool engine.
Got a bit more info for anyone that is looking.
Here are the two connectors (Green & Black) on the GPCM and
the two that the harness on each side plugs into.
Sean
Thank you for the information!!
It will help me out when I troubleshoot my truck tonight.
I have had the p0678 code which is #8 glow plug. This is also a common code for the GPCM. If the temperature is over 70F the glow plugs don't even come on so this time of yr might not be the best to know how things will go in winter. I replaced both the #8 glow plug and the GPCM and the code went away. GPCM is about $100
Can you point me to a place to get GPCM for about 100? I tried googling but some online store want almost 200 for one.
