Glow Plug error code
Old Aug 14, 2014 | 06:21 AM
78fordman's Avatar
78fordman
Just to be sure you changed the plug on the drivers side closest to the firewall correct?
Old Aug 14, 2014 | 09:29 AM
TruckingBill's Avatar
TruckingBill
Originally Posted by Yahiko
Here is one for $ 121.46 and it's a Ford part.
Diesel Glow Plug Controller for 2006 Ford F-350 Super Duty|YC3Z-12B533-AA
Sean
Thank you for the information.
Do you think based by my measurement that the GPCM is the culprit then?
Bill
Old Aug 14, 2014 | 12:24 PM
TruckingBill
yes on driver side nearest to the firewall.
Bill
Old Aug 14, 2014 | 04:40 PM
Yahiko's Avatar
Yahiko
Did you do some wiggling of the harness?
But it does look like that may be the problem.
When it comes to OPM I am not like some people
and just spend,spend,spend. BTW : OPM is Other Peoples Money.
Sean
Old Aug 15, 2014 | 11:54 PM
TruckingBill
I went ahead and ordered GPCM hoping that is the cause of the error code.
Bill
Old Aug 18, 2014 | 09:44 PM
TruckingBill
The GPCM have arrived.
I disconnected the battery so the code would clear while I was replacing the GPCM.
After replacing it, I hooked the battery back up and took it for a short test drive, the service light never came back on again.
Hopefully that fixes it.
Thank you everyone who posted inputs and feedback!!!
Bill
Old Sep 16, 2014 | 04:18 PM
TruckingBill
It been almost a month now and the code still have not returned so it look like it was the GPCM that was throwing the code.
I measured the ohm on the old glow plug that I replaced and it gave a good ohm reading.
So lesson I learned from this, next time I get a glow plug code ...... Check the ohms from glow plug harness first
Bill
Old Sep 16, 2014 | 06:34 PM
cheezit's Avatar
cheezit
Originally Posted by cheezit
Ohm from the 4 pin buss bar to battery ground, with the engine off.
Yup as stated in post 3. Good to hear its fixed
LSO1123
Jan 28, 2018 11:16 AM
newbie2006
Sep 19, 2014 12:04 AM
jereli
Jan 31, 2014 10:34 PM
foul1
Aug 16, 2010 05:57 AM
YoungMT Hick
Dec 13, 2009 05:21 PM
