Ok the truck has been running great. But it has been acting up some times. When i get on the gas it will sometimes cut out it wont die it just sputters a little bit and then runs fine. Also at 65-70 with cruise control on the truck acts like the tranny is slipping. I have changed the map sensor, the cam sensor, oil, fuel filter, air filter and no change at all. I am lost
Just going to throw something out there maybe it's the TPS ? Does it happen at the same throttle pedal postition each time it does it. You might want to take the dvm to your tps. Sorry I don't have specs off hand.
Is the check engine light on?
Are you able to do any data retrevial from the PCM?
Things we would like to know are:
Fuel Level
Fuel pressure
ICP pressure
Oil level (you said uoubjuat changed but let's check)
There are other possibilities but we will start there I think.
Fuel Level
Fuel pressure
ICP pressure
The fuel is never below a 1/4 tank
The oil level is perfect
The other 2 I can't check I have a Bluetooth obd2 adaptor but no program is there one I can download on my iPhone or computer
