Starters Starters Starters
Old Aug 10, 2014 | 04:58 PM
speedwrench72's Avatar
speedwrench72
All Idi starters are gear reduction. they use planetary gears, if your starter grinds, it may be your ring gear, is the problem. these engines stop at one of four places most of the time, and will ware at these places.
Old Aug 10, 2014 | 05:11 PM
tjc transport's Avatar
tjc transport
i ain't rite
actually, that is not true. the first year or two ford used a direct drive starter on the IDI, and some people used the direct drive when replacing a burned out gear reduction unit back in the good old days because the direct drive was cheaper.
Old Aug 10, 2014 | 05:16 PM
BruteFord's Avatar
BruteFord
I've looked at the ring gear, nor did it ever grind with the old starter.
Old Aug 10, 2014 | 07:13 PM
speedwrench72
All Idi starters are gear reduction. take it apart and you will see...just because its shafts appear to be in alignment does not make it so.
Old Aug 11, 2014 | 12:04 AM
Red454sedgwick's Avatar
Red454sedgwick
grinding can also be cause by the bolts being lose especially the top one
Old Aug 11, 2014 | 12:14 AM
BruteFord's Avatar
BruteFord
First thing I checked.
Old Aug 15, 2014 | 08:05 PM
Chevy_Eater's Avatar
Chevy_Eater
The planetary gear reduction starters do look like direct drive starters, I made that wrong call myself when I first saw one.
However, Tom is correct in that the first couple of years of the IDI a direct drive was used, it's a bulky Delco unit.
Old Aug 15, 2014 | 08:10 PM
Chevy_Eater
As a matter of fact, I just looked it up at Rockauto and they are still available and the part number confirms that it was only used for 1983 and 1984:
ACDELCO Part # 3361815 {#19136124} Professional||Remanufactured
DELCO; 25MT; Unit MFR DE; kW Rating 3.6; Drive Direct Drive; 336-1815; 6Y2; 0050A
Old Aug 15, 2014 | 08:12 PM
BruteFord's Avatar
BruteFord
I ordered the DB from Amazon, should be in here in a few days.
Old Aug 18, 2014 | 07:40 PM
BruteFord's Avatar
BruteFord
I got the DB SND0027, it has an extra plug on the side, a flat tab with a screw shielded in rectangular plastic. What is the purpose of this connection? Been looking on the DB website, can't find it and it came without instructions.
You can see it in this pic.
Popup Window 319274
My thought of course is that this is it's own solenoid, if so I need to do a little extra wiring. It's a large connection to however so I'll need to know the draw.
Old Aug 18, 2014 | 09:07 PM
totalloser's Avatar
totalloser
That's just the solenoid wire from the ignition switch. It goes in exactly like the OE except that the big battery positive wire will need to be bent 90 degrees to go on.
It's very easy, and they work VERY well. I just got a third on for my buddy's f450. They are so much faster turning that they start like a direct injected engine. Quality internally appears as good as any other starter. They look like a monster Toyota starter- nippon denso style.
I don't think I'll ever run a stock one again. No comparison, WAY better IMO.
Old Aug 18, 2014 | 09:16 PM
BruteFord's Avatar
BruteFord
Battery cable to big post, solenoid wire to this tab?
I think I had a brain mishap, that's how it's wired stock. For some reason I thought it was a one wire like the gassers. I just put a starter on a 5.0 so I have an excuse, lol.
WAY better IMO.
I'll find out tomorrow I hope.
Old Aug 20, 2014 | 12:39 AM
  #28
BruteFord's Avatar
BruteFord
It's in, think it safe to say that it spins faster, hard to say, it does sound different, of course no grinding, and my truck always starts quick. Maybe tomorrow I'll try it before the glow and see what it does.
Got to thinking from the looks of the start wire plug there is probably some factory plug for that, anyone know if there is and if so where to get it?
Old Aug 20, 2014 | 12:33 PM
  #29
fordiesel69's Avatar
fordiesel69
Try the mitsubishi units from autozone. They last about a year, but have a lifetime warranty.
schlepprock250
19
Aug 21, 2017 09:38 AM
Furr308
18
May 5, 2015 10:19 AM
Automator
17
Aug 15, 2013 02:42 PM
01FordCrew
Sep 19, 2009 01:37 PM
gskershner
Feb 26, 2007 02:23 PM
