Looking for help with exact location and amount of effort required to replace the ICP on a later 2004 ICP (newer style sensor). First Diesel - like it alot - want to get the light in the dash turned off before the performance drops off.
thanks for your help.
MS
04 engine ICP sensor is located at the front of the passenger side valve cover. Takes about 60 seconds to change. If you have a CEL on an 04 please post up the codes. Kinda rare in my experience.
Does anyone know what the normal readings are for the ICP,my computer dump most of my info....thanks
Take this test in park , no HVAC
ICP
KOEO-0 (key on engine off )
low-625.5 (just Idle)
high-1400/1450 (at 2500rpm)
ICPV
koeo-0.22(.82)
low-1.0
high-1.8
Just in case you like pressure readings it takes a min. of 500 psi to start 650 to 700 at idle 1200 to 1500 about half throttle and 3000 to 4000 full throttle.
PS: I seldom see 4000 except on a newish truck. Useually 3500 to 3800
