source for body mounts?
Old Aug 8, 2014 | 09:36 AM
Greg5OH's Avatar
Greg5OH
I wan tot get new body mounts for my build, keep it rubber to keep NVH down in the cab. Cannot find on rock auto and dealer wants wayyy too much. Where else cna I get them?
Also I need the two rubber rad core supports for the front.
thanks!~
Old Aug 8, 2014 | 10:26 AM
Mike1's Avatar
Mike1
Try here: Ford Bushing Kit - JCWhitney
Old Aug 8, 2014 | 01:49 PM
Diesel_Brad's Avatar
Diesel_Brad
Just a FYI, that is myth about Poly making it noisier. It put them in just about every truck and have ZERO increase in noise
Old Aug 8, 2014 | 02:58 PM
GuitarJesus's Avatar
GuitarJesus
^x2. Helped my friend do his CC and the old mounts squeeled like a hog. New Poly mounts and a quiet comfy ride.
Old Aug 11, 2014 | 02:38 PM
Greg5OH's Avatar
Greg5OH
so i called energy suspension, anbd theyre telling me ther eis no metal inside the bushing..
how does one screw the bolt into the bushing?!
I dont have any factory hardware or factory body mounts. I have a bare frqame.
Doesnt the stock rubber have a metal sleeve cast into it which is threaded, into which you thread the cab bolt into?
Old Aug 11, 2014 | 02:57 PM
danr1's Avatar
danr1
LMC truck has em,
Not sure this will be a direct link, (if not you want page 21 and 22)
Truck Parts and Truck Accessories
Having nothing but bare frame, they offer the complete mount setup you're gonna need.
You can however order the poly bushing kit page 21 then the hardware you'll need to use with it from page 22, if you'd rather have the poly bushings instead of rubber for example.
The body bolt screws into #15 front of cab and #22 rear of cab in the diagram shown page 22.
Old Aug 11, 2014 | 03:09 PM
Greg5OH's Avatar
Greg5OH
wondering if the bolts and such will be the same as for an 06?
sorry im all over the place with the years.
I have an 06 frame which my 91 body is going on to.
I actually do have 4 OEm body mounts lkaying here off an 05 truck so i can use the sleeves from there, just need the bolts. not sure if its metric or not. But LMK doesnt list anything for body bolts in their catalog which is considereably harder to use than for OBS.
ah *** it, ima just make my own retainers. Screw spending 20 bucks a pop for something like this.
Old Aug 11, 2014 | 04:14 PM
Diesel_Brad
Energy suspension has you reuse the steel sleeves from the original rubber bushings.
OBS bolts are 7/16
SD bolts are metric
LMC is pretty much JUNK
Old Aug 11, 2014 | 08:26 PM
LeoJr's Avatar
LeoJr
I've lost track if this is for an OBS or SD, but I have changed my OBS crew cab to black poly from Energy Suspension.
Do some research and have a plan to pull the old ones apart. Impact (hammers, etc) won't do it. You'll need to fab a puller. And when you have the two metal pieces apart cut at least one of the bulged ends off so you never have to fight them apart again.
Have new front (radiator support) bolts lined up (if not already in hand, you can return them if not needed) as they will most likely either be corroded and snap in half or you will have to cut them. Also have two or three long extensions for your socket on the top side with a backer wrench on the under side and this is a one person job.
And though Brad says I'm hearing things, I did initially hear a new type of sound. But when I priced rubber replacements at about 4 sawbucks I couldn't hear the sound anymore.
Bgilmore480
Oct 9, 2017 09:02 AM
bulldogcountry1
Aug 22, 2017 10:40 PM
Watcher58
Sep 27, 2015 01:37 AM
Bonkrr
May 2, 2005 10:59 AM
tygarcia
1978 - 1996 Big Bronco
Nov 7, 2003 05:55 PM
