Egr
Old May 21, 2006 | 10:42 AM
david11690's Avatar
david11690
Egr
What does it mean to have a little coolant residue under the EGR?
Old May 21, 2006 | 11:20 AM
Maxium4x4's Avatar
Maxium4x4
Define under? No coolant should be present unless you have a leak.
Old May 21, 2006 | 03:28 PM
vloney's Avatar
vloney
egr cooler is leaking. High egt melts the brazing inside the cooler assembly. Overboosting is a likely cause of this. Others can be the cause, but by far its overboost
Old May 21, 2006 | 03:53 PM
CanadaGuy's Avatar
CanadaGuy
Letting the coolant run too low that the EGR cooler is empty will also cause them to melt down... and fast. But, are you sure it's coolant??
Old May 21, 2006 | 05:47 PM
david11690's Avatar
david11690
I pulled the EGR up and out of it's location to see if it needed cleaning and notice some sort of moisture and thought it had to be coolant.No I'm not sure it was coolant.
Old May 21, 2006 | 06:05 PM
CanadaGuy's Avatar
CanadaGuy
I've removed quite a few EGR valves, and sometimes there is a bit of moisture on them. Are you losing coolant? Normally when an EGR cooler is leaking, I find that the valve is almost covered in mud, or very clean depending on how severe the leak is, and sometimes the o-ring is melted. As gross as it maybe, I give them the taste test to determine whether or not it is coolant.
Old May 21, 2006 | 06:12 PM
david11690's Avatar
david11690
Coolant level seems to be the same. No I could not bare to taste that moisture and the vehicle seems to be running well.
Old May 21, 2006 | 07:30 PM
Maxium4x4's Avatar
Maxium4x4
Now how do you expext us to know if you don't taste test the EGR....
