When I start up the Excursion with the HVAC in auto mode there is no air blown through the dash vents. Only through the defrost vents. Can any one tell me has my dash controle module died?
Sounds like you have a vacuum leak. Does it change when not in auto mode? If not, check the vacuum pump or the lines for a leak. This is a diesel truck I assume?
In particular, look at 4x4 lines and at the vacuum switch housing. Again, assuming you have diesel 4x4 with vacuum pump and vacuum operated front hubs. My 2003 did this and it was an easy 'patch' to stop leaks in 2wd until I could get to Ford dealer for a new vacuum switch for 4wd.
