A couple general questions
Old Aug 4, 2014 | 11:18 AM
Shadowrider123's Avatar
Shadowrider123
Should there be welting between the rear fenders and bed on a 64 flareside?
Any local options for stainless steel fender to bed bolts or do I have to go through mail order?
How come my 64 short bed doesn't have the spare tire cutout in the left fender? I thought they all did.
When hot at idle my oil pressure is about 10lbs or less. I have not checked the gauge for accuracy yet. I noticed the oil pump on the 292 is external, is it rebuildable without dropping the pan?
Old Aug 4, 2014 | 12:00 PM
schoo's Avatar
schoo
I used welting at the rear fenders I painted to match body
fender bolts are welded on and mar-k sells them and others
spare was an option not every body wants one and it could go under frame
my oil pump was replaced in 1988 and works just fine 45psi at idle
Old Aug 5, 2014 | 10:20 AM
sseebart's Avatar
sseebart
If memory serves, yes, you can pull the pump without dropping the pan. But, you could have a clogged intake, so best to figure on doing it all.
~Steve
Old Aug 5, 2014 | 11:09 AM
Shadowrider123
My plan was to blow air back through the pickup once the pump was removed.
Old Aug 5, 2014 | 12:33 PM
sseebart's Avatar
sseebart
Hmmm. If it's all clogged up, can't think of anyplace good the gunk would end up with that method.
Old Aug 5, 2014 | 12:37 PM
svolpone's Avatar
svolpone
pump it into the cab of a chevy.
Old Aug 5, 2014 | 12:40 PM
Shadowrider123
I don't know if its clogged up or not, I don't know if it is working properly or not.
You are speculating on a lack of information.
Here are the facts as I know them:
1. I have owned the truck for 2 weeks, previous information unknown.
2. The truck is 50 years old, all information on the engine is unknown.
3. The oil pressure gauge reads 30psi at start up, 10 psi at temp. Accuracy of the oil pressure gauge is unknown.
Old Aug 5, 2014 | 04:01 PM
sseebart's Avatar
sseebart
I can only speak from my own experience. I've twice tried to increase oil pressure with new oil pumps, and in both cases it was not the pump, but worn bearings that were the culprit.
One of those was a 292 in a '64 F100 (back in the '80's)--it had oil pressure exactly like yours. Ran good, no smoke, not a ton of power though, either. When the new pump didn't have any effect, I went ahead and rebuilt the motor, which brought the pressure (and power) up to normal.
I talked recently with a machinist about my current truck (A '62, also with the 292). My mechanical gauge shows about 40 psi at speed, 30 or a little less at warm idle. He thought I was doing all right--his rule of thumb being 10 psi for every 1,000 rpm. (I am still planning a rebuild sooner rather than later.)
If this is a truck you want to keep, sounds to me like a rebuild is in order once you confirm the gauge readings you're getting. If it's just a driver, you're probably ok to leave it as-is, as long as you don't push it too hard. A new oil pump may help, but I wouldn't put a lot of faith in that curing your problem.
~Steve
xtrmbkr
Jul 8, 2017 10:56 PM
1956f350
Apr 3, 2013 10:01 PM
berkad
May 26, 2006 01:29 PM
ferguson777
Oct 17, 2002 08:29 PM
62stepside
Dec 21, 2001 11:27 AM
