Acceleration Issues
Old Aug 3, 2014 | 10:09 AM
BLADE35's Avatar
BLADE35
Your CAC system is Fine
you can try to clean out the MAP Sensor and TUBE it might be reading low from SOOT Buildup
Lots of MAYBE's without a Gauge
Old Aug 3, 2014 | 11:13 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by 9228.bobcat
Veins sticking from coking or rust. Good cleaning should help
Originally Posted by BLADE35
sounds like turbo is stuck
But you need a Gauge to check the turbos Control sensors
BARO
MAP
MAFV
vgt
These two posts tell the tale. An 03 with only 83K on the clock probably hasn't been driven much leading to turbo rusting causing the vane and unison ring assembly not to work properly. Only a good cleaning will help.
As Blade suggested, get a scangauge 2 (about $115 at Advance Autoparts with online code) or one of the smart phone apps to monitor what you're truck is doing. The dash gauges are worthless for the most part; basically idiot lights with needles.
Old Aug 3, 2014 | 11:25 AM
BryanStein's Avatar
BryanStein
Agreed. Turbo issue. Have you driven it much since purchase? If not, drive it at least once every other week. Preferrably once a week. Otherwise the turbos want to get sticky.
If you want to keep the truck, get some gauges. I use Torque Pro. It's an android app that costs $5 and you be to get an OBDII Bluetooth reader from fleabay. It will run about $20. I monitor about every fifth time I drive the truck. Treat the engine well, and time will be very happy.
Old Aug 3, 2014 | 01:20 PM
m-chan68's Avatar
m-chan68
'03 trucks are a very unique animal compared to '04 and up trucks. That vehicle is doing almost exactly what attempting to drive one with the air cleaner and MAF sensor disconnected will do. The best way to resolve the issue is to ensure there are no aftermarket intakes or exhausts. No issues with MAF as well as EGR and IAT #2. Assuming the VGT is functioning correctly will also help too, although the last '03 I had with a failed VGT solenoid wouldn't produce ANY boost at all if it helps.
Old Aug 3, 2014 | 03:22 PM
PappyUSMC's Avatar
PappyUSMC
Lately, I have been driving it daily for about 90 miles each day.
Old Aug 3, 2014 | 03:25 PM
PappyUSMC's Avatar
PappyUSMC
So if I get a OBDII Bluetooth sensor.... it will function for all the required gauges?
Any specific model/brand you all use that you recommend?
Dashcommand any good?
Old Aug 3, 2014 | 04:32 PM
Misky6.0's Avatar
Misky6.0
It is more important the bluetooth adapter work with the device you plan to use to monitor it with, IF you plan to use bluetooth, other devices use a cable (sg2) thus no need for bluetooth
There are pc apps you can get, forscan is what i have on my surface pro.
There are apps for smartphones, and thwre are other devices/programs as well.
I use scangauge2, since it is instant on and displays without have to do anything. It is old school tech, but doesn't require attention.. it also can be configured to monitor any existing sensor value, using xcode to program it in, many alternatives provide a list of sensors to pick from, you are limited to what it provides.
The dashboss and new devices are also popular.
Sent from my Sprint PC36100 using IB AutoGroup
Rob89
Sep 11, 2016 12:25 PM
F2502011
Jun 5, 2014 11:08 PM
Fomoko1
26
Sep 9, 2011 03:13 PM
