U Joint Replacement Zirk Direction?
Old Aug 1, 2014 | 06:07 PM
PancakeF150's Avatar
PancakeF150
I am replacing the U joints and didn't pay attention to which way the grease zirk was facing. I indexed the shaft yoke with the differential yoke but I need to know which way to face the zirk. Should the zirk face the shaft or the diff?
Old Aug 2, 2014 | 12:22 AM
tbear853's Avatar
tbear853
You'll reach it easier if it angles towards the drive shaft and the joint will take more torque if the threaded hole is "in compression" under power.
Or you can get Super Strengths that have the zerk in the end of one bearing cup.
Old Aug 2, 2014 | 02:16 AM
psychlopath's Avatar
psychlopath
Originally Posted by tbear853
...the threaded hole is "in compression" under power.
Old Aug 2, 2014 | 01:38 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
As far as I know it does not matter what direction, just as long as you get the end of a grease gun on it. If its in wrong you can't get the end on there.
And adding a longer grease zert with a 90 is a "fail", better to just flip the u joint around to ghet the zert in the right direction.
Old Aug 2, 2014 | 10:36 PM
tbear853's Avatar
tbear853
Well, one way you can usually get the regular grease snap on end to work, the other way you may need to use the tip with concave plastic tip and hold it tight to the zerk.
J ballan
Aug 31, 2017 09:50 PM
78longbed
Oct 10, 2009 10:46 PM
KIOTI
Feb 10, 2009 04:11 PM
thndertruck
1978 - 1996 Big Bronco
Nov 14, 2002 12:55 PM
fast freddie
Aug 28, 2001 08:13 PM
